1989 Convertible Top - 1 Year Only Top?
Old Apr 18, 2022 | 11:18 AM
Bohemian's Avatar
Hawks just told me the 1989 has a one year only convertible top.
is that true?
everything i've seen said 87-92 are the same...
the top i bought from topsonline said 87-92...
hope somebody can shed some light on this subject and IF 1989 is a one year only ASC Top, what are the differences from the rest of the 87-92 tops?
thanks in advance.
Old Apr 18, 2022 | 12:07 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: 1989 Convertible Top - 1 Year Only Top?
I'm here because I have an '89 IROC Z Vert, too.
Old Apr 19, 2022 | 11:49 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I think the '87 top is a one year only.
Old Apr 19, 2022 | 03:03 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
there are 3 different top frames.
87
88-89
90-92
You need to take measurements of your top to make sure you order the correct top for your frame.
Later,
Chris
Old May 26, 2022 | 01:10 PM
Bohemian's Avatar
in a old related thread here it says the following with no more detsils...
There Are At least 3 different style tops for third gens:
87-88 (slider Tonneau release 87-88 front bow and window)
89 (handle Tonneau release 89 front bow and window)
90-92 (handle Tonneau release 90-92 front bow and window
really having trouble finding out what exactly the specific differences are...
with my ongoing challenges with weatherstripping not being cut at the correct angle it sppears that 1. The weatherstripping for over the windows is not the same for 87-92 like topsonline and others indicate. 2. The angle of rotation for the top side window rails that the weatherstripping slides into is different for 87-92. 3. The weatherstripping manufacturers all knocked off one year between 87-92 and called it good for 87-92. 4. I may not have a 1989 Convertible top frame on my 89 rs vert or it may be some hodgepodge of 1987-1992 vert top frame parts. 5. I may need to get custom made weatherstripping for my top window roof rails a little longer than what I have and just sand the angles I need to make it work. I have no idea who can do that or how much it would cost. I know it can be done because FantomWorks had it done for a 63 corvette split window they were customizing on the tv show on cable sone time back.
this is currently my best guess based on what i'm seeing with my 1989 vet.
It'd sure be useful to know WHAT is different between 87-92 convertible top frames and weatherstripping, not just that they're different.
Pictures of the differences side by side would be awesome.
thanks in advance.
Old May 26, 2022 | 04:05 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
I believe 87-88 are usually mostly the same
89 is a 1-year
different bow trim, tonneau release, smaller window, different header and latches
They made a lot so there’s still reproduction trim pieces for 89
90-92 is slightly different. Different bow trim, different window, different header and latches
apparently if you’re ordering a top they may have switched styles mid-year so you really need to measure and confirm for the fabric.
https://www.convertibletopguys.com/c...evrolet-Camaro
https://www.convertibletopguys.com/c...o-IROC-RS-Z28-
Old May 26, 2022 | 08:43 PM
chazman's Avatar
Axle/Gears: BW 3.45
89 is a 1-year
I've never found and aftermarket top with white stitching, like the factory/ASC ones had.
Old May 26, 2022 | 09:36 PM
Axle/Gears: G80 GU2
The convertible top guys I quoted might be able to do it… I believe you can pay extra and they consider it custom but if you talk to them they might be able to…
Sopel
Exterior Parts Wanted
16
Dec 12, 2025 11:35 AM
Tonkatoy
Convertibles
Jul 7, 2010 07:22 PM
89ragtop
May 14, 2001 05:42 PM
