Convertible owners.....
Old May 13, 2001 | 07:43 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
How many of us have electric trunk releases?
Please specify make and year. Thanks.
Edit: Oh yeah. Yes or no?
[This message has been edited by 89ragtop (edited May 13, 2001).]
Old May 13, 2001 | 08:15 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
None of us have electric trunk releases. This function has been diverted to the tonneau release solenoids. The trunk pulldown mechanism still functions as such, you just can't "pop it open" with the console switch, only with the trunk key.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old May 13, 2001 | 08:37 PM
89ragtop's Avatar
So does the mechanism that is there serve to release the trunklid? If you supplied power to it would it pop the trunk? The only reason I think they didn't wire up a switch for it was so that you wouldn't accidentally pop the trunk while the tonneau cover was up. I just was thinking how it's wierd that it is there, but not hooked up. Maybe put in before it went to ASC? Otherwise why would they waste the parts? GM is cheap and I'm sure they would try to save dollars everywhere they could.
Old May 13, 2001 | 09:30 PM
CamaroRS1989's Avatar
Car: 1989 Camaro RS. Nissan Altima
Engine: 2001 5.7L LS1
Transmission: 4L60E w/ Circle D 3500-3600 Stall
Axle/Gears: Stock 3.42
That explains why I couldn't find the button to pop the trunk when I was looking at this convertible I might be getting. Hey, what are the bad things about having a convertible? Oh yeah, where do I find the rpo codes? Are those all the #'s and letters inside the middle console box?
[This message has been edited by CamaroRS1989 (edited May 13, 2001).]
Old May 13, 2001 | 10:01 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
<font face="Verdana, Arial" size="2">Originally posted by CamaroRS1989:
</font>
Yup those are the RPO codes. Just make sure you invest in a set of Sub-frame connectors.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old May 13, 2001 | 10:41 PM
89RagTopRS's Avatar
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
89ragtop
The trunk motor is the same, so in theory you could make it release the trunk. I saw a 91 TA convertible with the tonneau release on the tonneau itself right by the driver side door (great idea). It had the trunk release in the center where it normally is. The switch itself is different than the normal release(as far as I know) but the real switch is easy to get. Since they started as coupes, they should have the wiring running through the car(but GM is cheap so... )
CamaroRS1989
Have fun finding a strong set that fit the convertibles. I was unimpressed with the ones available, although I maybe forced to choose. Chassis flex is the worst and it causes numerous squeeks and cowl shake (mine does, don't know about others).
Bad things about having a convertible
  • flexable flyers
  • not given the best motor
  • weighs over 2 ton with a normal person and a full tank of gas
  • Hard to find parts(they're always the ones that break
  • tendancy to squeek more than most
  • People staring at your car and not paying attention to the road, creating a hazard for you and others around
The Good
  • People liking the car, staring at the car
  • Knowing you are 1 of the few, the proud, the 3rdgen convertible owners
  • Having people on this site drool over your car
  • Being able to show off and look good doing it
  • Looks good, even when in bad shape(with top down only)
  • People don't expect it to be fast b/c its an overweight convertible
  • Almost Everyone Wants One
*rambling on mode off
edit: Having a bad spelling and grammer night
Member of the Jersey Fbody Crew(JFA)
1989 Camaro Convertible RS
dark silver w/black top
305tbi, auto, 2.73 posi
SLP exhaust, 16x8 black
Check out Phil's Rice Boy Page
<font face="Verdana, Arial" size="2">It all came back to him as he pissed into the wind</font>
[This message has been edited by 89RagTopRS (edited May 13, 2001).]
Old May 13, 2001 | 11:00 PM
89ragtop's Avatar
Yea, like Willie said, they rerouted it to the tonneau solenoid when it is in the center console. I knew it was there, like I said, just wondering why they would install it and not have it functional? Waste of materials is not real smart. I have a switch out of a coupe, maybe when I reupholster the sunfaded interior (not now, but when it gets bad enough) I'll wire it up. Not like anyone uses their trunk much in a vert (can't fit shiet in there).
BTW, I have the custom cloth (forget the exact name) the thin black and white stripe cloth. Can the original material be bought to reupholster the seats? I don't want to go leather, and the door panels don't need it.
Anybody know if anyone carries this pattern?
Old May 14, 2001 | 06:40 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
In 91 they moved the tonneau switch to the tonneau vice the console. My 92Z28 has it there and it's much more convient then my 89 RS which is on the console. I doubt you could get the release to function properly. On a hard top, when you pop the hatch, the angle on the gas struts is such it will hold the hatch up slightly so the pull down does not re-engage. The angle is so short on a convertible trunk I think the lid would drop and me pulled down as soon as the pull down motor cycled. I could be wrong though...
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 14, 2001 | 11:28 AM
jm91rs's Avatar
what would it take to make a trunk release work then?
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon......"Custom" non-red material.
Old May 14, 2001 | 11:43 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I have a trunk release in addition to the tonneau release. But only because I added the solenoid and wiring from a coupe. I installed a release switch from a Caprice inside the center console along with the light that lit it's glove compartment.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old May 14, 2001 | 12:05 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I have a 1990 Convertible,and I was thinking about installing a trunk release switch where I believe the Rear defrost button would normally be on the coupes(Bottom right of instrument surround). There is just a bare plastic panel in there now and it looks like the trunk release button would fit nicely.Do you guys think this would work?
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered
Old May 14, 2001 | 03:21 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Weird, so the rest of you vert guys have an electric pulldown on your trunks...mine doesn't.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old May 14, 2001 | 05:42 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
I added it to mine. I bought the solenoid from GM, and wired it. I have the release button on my key chain only so if some one get's in the car, they won't get to the trunk. You could also wire it so the switch was powered when it had the key on.
89'Camaro Convertible,96'firebird wheels,79'Z28 hood scoop, Dark yellow green paint from Bonnevilles, tan Mr. Mikes leather interior,Macewen white face gauges.
Dreaming of a RamJet 350,
Open element
Jet fan switch
180 degree thermostat
2nd place is always the first loser!
[This message has been edited by 89rsvert (edited May 14, 2001).]
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
