honik tranny coolers and cooling mods :-)
Old May 29, 2002 | 03:26 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
91 vortec headed hotcammed 350 tpi here :-)
running a flowkooler water pump ,180 degree stat, and reset fan speeds in the ecm(burn my own proms )
what alternatives to we have for radiators other than griffin for max cooling? i like them i wont argue but another 500 in this thing and im gonna by a new one :-)(not yet at least)
Recent trans rebuild and vigi converter have now resulted in a tranny cooler in the already precious area for nice air to hit the radiator :-( does tend to run hoter now and take a lil longer to cool back to 180 rane when cruising...............
getting a gn fan switch for my 2nd fan(have to replace headgasket leaking oil (luckyme)) so it should be coming on in the 205-210 range now in addition to the primary fan ....at about 185-190 i have the primary set to come ......
just rambling basically lol
so gimme your opinions on making her run cooler :-)
whos got the hot ticket
later
Old May 30, 2002 | 09:18 PM
DM91RS's Avatar
Car: 91 RS
I have no complaints about the $190 Griffen
Old May 30, 2002 | 10:30 PM
3.8TransAM's Avatar
hmmmm i dont see a tranny cooler there?(i gots a huge one)
and is that a direct bolt in or what?????????????
doesnt quite look same size as stocker?
Old May 31, 2002 | 05:48 AM
DM91RS's Avatar
Car: 91 RS
I have a 5 speed. Were you wanting to get rid of the cooler that you have now?
Not quite a direct bolt in but was done in an afternoon. I had to mod the core support and I still have to find better rubber mounts. It's a very tight fit between the frame rails. Spaced the fan back .250" and spaced the top support up .250
It is twice as thick as the stocker.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92camaro350cci
Oct 14, 2015 09:29 AM
apie2546
Sep 20, 2015 01:03 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
