Has anyone mounted a pusher fan in front of radiator?
Old May 31, 2002 | 06:57 PM
RODS92Z's Avatar
Often thought about putting one on the front of the radiator to push air into the radiator. Has anyone done this and what kind of fan setup did you use? Thanks.
Old May 31, 2002 | 07:25 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I did it a few weeks ago. I used a pusher fan from a 83 daustun Z that has a rock guard built in it. I put it on the passenger side infront of the AM tranny cooler so the fan serves a dual pourpouse, transmission and engine cooling fan. As far as connections and swiches, I just spliced into my AM fan swich, you could splice into your stock fan wires if you have an electric fan.
It only droped the water temp a few * but Im sure the transmission is running a lot cooler. Every bit helps.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
Terrell351
Jun 13, 2021 01:13 PM
