water pump?
Old Jun 1, 2002 | 02:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
water pump?
do i need a reverse rotation water pump on my car? would it still work with a standart rotation water pump? do i need a long or a short water pump?
Old Jun 2, 2002 | 11:28 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Sounds like you no longer have the stock motor in your car. I think the only motors that came with the reverse water pump what the L4's. Not sure. If you have an older block, I think a normal pump would be fine. Also if you know the year of the block and the info about it a part store should be able to tell you weither long or short pump is needed. What happen to your old one??
Old Jun 2, 2002 | 11:53 PM
well i have since answered my own questions and ordered a stewart stage one water pump
i have a long reverse rotation water pump, and i have to have reverse rotation due to the serpentine belt setup
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
