Secondary fan not coming on
Old Jun 25, 2002 | 08:46 AM
STOCKROC's Avatar
can anyone tell me, or show me a picture of where the relay is located for the secondary fan.
Old Jun 25, 2002 | 09:01 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
On the left side looking at the engine it will be above the battery sitting all by itself. It screws into the inner fender near a ground wire. Remember if stuck both primary and secondary relays ARE interchangeable. Also the blower motor relay is the same part #. You can use it for a test. Dan 1989 IROC zz-4 block, otherwise bone stock.
Old Jun 25, 2002 | 09:05 AM
STOCKROC's Avatar
Thanks alot! I will try that.
Old Jun 27, 2002 | 11:50 AM
5SIZ's Avatar
Car: 1987 IROC-Z
the reason your secondary fan does not coem on is because the factory temp for it to come on it 245 degrees! thats way to hight for me, ewhen you hook up a switch to it and turn it on early your car will run a good 20 degrees cooler
Old Jun 27, 2002 | 07:37 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sec fan turn on temp is 238. It is NOT way high. It is well within spec's for a pressurized system. Every car made in the last 20 or so years including one of my sportbikes runs at 195. Believe it or not the cooling system works the best when it is at full pressure and above 220 degrees.
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
