coolant to water ratio
Old Jun 27, 2002 | 12:17 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
what ratio of coolant to water do you run. should it be like a 50-50 mix or like a 30-70 i have no idea. i put to much coolant in now its overheating.
Old Jun 27, 2002 | 05:04 PM
Sciguyjim's Avatar
Usually 50:50 is suggested but other ratios are acceptable. The "active ingredient", the thing that does the heat transfering, is the water. The glycol is just there to prevent freezing and raise the boiling point (also pressure). Using more water will result in a mixture which pumps easier and transfers heat better. Using more glycol will give you a thicker mixture with a higher boiling point and lower freezing point and more corrosion protection. Using 100% glycol is not good. So, it depends on what you're looking for and your climate. 50:50 is a good compromise.
PS. Use distilled water, not tap water, and you'll have less chance of getting mineral deposits in your radiator.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
