whats wrong here?
Old Jun 29, 2002 | 02:06 PM
32789RS's Avatar
whats wrong here?
I went to the junk yard, to get a dual fan setup for my 89 RS, I got the radiator, both fans, upper and lower fan mounts off an 89 IROC. Well I go home and start to put this all in only to find the lower fan mount is much longer and wont fit where the single fan mount was. Has anyone else had this problem and what did you do to make it work.
Old Jun 29, 2002 | 05:21 PM
dale davidson's Avatar
by lower fan mount, would u mean the part that would take the place of a lower fan schroud if the car had a mechanical fan assembly? or do mean the part that the fan it self attaches to( i believe one resembles a "K" and the other a "Y"). theres a link for this conversion. some one should know where too.
Old Jun 29, 2002 | 06:35 PM
32789RS's Avatar
it's the one the fan itself bolts to. none of the holes on the radiator support match the holes on the lower fan mount.
Old Jun 29, 2002 | 10:34 PM
troberts2's Avatar
Very surprised to hear this. I did exactly the same thing, to the same car, from the same donor car, and everything bolted up quite nicely to the original lower channel and upper shroud. These dual fans each have a "Y" mount, 2 bolts bottom and 1 bolt top.
One thing I learned the hard way, these fans sit much closer to the radiator fins and actually sucked themselves even closer at speed, resulting in a circular gouge that opened several tubes.
Longer bolts and 0.20' thick shims (and a new radiator) solved that problem.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
