i give up!!!!!!
Old Jul 1, 2002 | 04:31 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
i give up!!!!!!
i have replaced eveything on my cooling and still run hot 210-220 on hot day i jus put in a friends griffen radiator in and it still runs that hot ive got a edelbrock water pump i have my air dam but i jus order a new one i think im going to take my running light out to give it more air i have alum heads and i put 2 cans of 40 below in nothing seems to help im running 10.4-1 comp 383 any ideas?
Old Jul 1, 2002 | 04:47 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
be happy that your engine runs that cool, im trying to get my stock LO3 down off of 240 going down the highway. 210-220 all day on a hot one is pretty reasonible to me.
Old Jul 4, 2002 | 09:34 PM
89Irocz23's Avatar
I dont kno any of the cooling issues on the lt1 intake, but im im the process of doing it so I dont know. how do you have your fans wired? Also is it single or dual fans?
Old Jul 5, 2002 | 05:55 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I can tell you from experiance that it's not the LT1 intakes fault.
I too run a 383 stroker and get up to 220° - 230° even before the LT1 intake swap. I was traditional LTR at that time.
I swapped to the LT1 intake and still run the same temps.
I am in the process of installing Griffins BIGGEST radiator, a dual 1 1/4" tube universal.
If I still run hot then the A/C condenser is coming out!
Old Jul 5, 2002 | 08:52 AM
scauffiel's Avatar
My 383 also gets up to around 210-220. I just watch it carefully.
S.
Old Jul 5, 2002 | 09:29 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would look into how you fans are wired
Old Jul 5, 2002 | 12:07 PM
dale davidson's Avatar
ditto
i was headfing down the cooling system war path, thinking that the fan worked because it came on when i flipped the manual switch. turns out that when the engine reached OT, the fan was reduced to a crawl, fans can suffer from heat soak, consider it.
Old Jul 6, 2002 | 09:17 AM
327 firebird's Avatar
what octane gas are you running? with a 10.4 to 1 compression you need better than 92 I would see if you can find some 94 and maybe a bottle of octane boost might help. I have a 10-1 compression on my 327 with alum. heads and intake which I run with 12 degress advance and I think 34 total advance. I know with anything higher than 10-1 you need better than pump gas or you get detionation which = overheat or hight temps. also you could retard your time to make up for it, but as you know you wont get as much power. Up here in New England area I know Sunoco sells 94 octane but I dont know if they have it where you are, but you can get 87 and a bottle of octane boost brings it up to 104 and thats probally cheaper plus it works for 2 tankfuls Hope it helps... Erik
Old Jul 8, 2002 | 12:50 PM
MdFormula350's Avatar
what thermostat are you running? and what kinda fan setup?
Old Jul 8, 2002 | 02:11 PM
Car: 92 camaro
Engine: 383 stroker
i had a 160 i jus swapped it to a 180 when i put the griffen rad in and im running a singole fan i think its like 2850 -3000 cfm its one of the biggest cfm jegs sells i think i might be running a little lean
Old Jul 8, 2002 | 03:48 PM
Sounds like you have enough air and a good enough thermostat, i dont know what to tell you, maybe someone else does. Is that the temp when you are riding down the road or sitting in traffic?Have you made sure that your gauge is accurate?
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
