Rewired fan....messed up fuel pump?
Old Jul 6, 2002 | 01:31 PM
rscamaroman's Avatar
Yesterday I tried wiring my fan to run with the ignition on. A friend told me to tap into the green and white wire which runs into the fan relay, and run that wire to a toggle switch. I also ran a ground wire to the other end of the toggle. Well heres the problem, after doing that my car doesn't want to start! I don't think the fuel pump is kickin in. I tried repalcing the fuel pump relay, but that didn't help. If you continue to crank the car, it will eventually start and run fine. I think this is because it will eventually bypass the relay and run the pump off the oil pressure switch, but why didn't the new relay work? I think I really screwed something up.
Has this ever happened to anyone else? What should I try.
My uncle said I might have tapped the fuel pump relay instead of the fan, but I used the one it showed in my locator manual.
If I did tap into the wrong one, what could that have done?
Old Jul 7, 2002 | 03:00 PM
jimbuck's Avatar
Sounds like you got the wrong relay. I had that problem, on mine (91) there were 3 relays, the one that was supposed to be the fuel pump was actually the fan. Someone had just moved them or they were installed differnt than the book said.
Old Jul 7, 2002 | 07:46 PM
hey jimbuck
You said that you had that same problem, but did yours mess up the fuel pump priming like mine? If so what did you do to fix it? I think mine is the ECM. I've tried the relay but its not getting current from the ECM.
Old Jul 8, 2002 | 12:36 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ttt
i had the same problem, carb solved it fuel priming the engine is in the bowls now
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
