convert from single to dual fan setup?
Old Jul 6, 2002 | 03:36 PM
mckenzie's Avatar
Hello, i have a 86 iroc 305tpi with a single fan setup. i would like to convert to a dual fan setup. have any of you all done this or know of anybody doing this. what all would i need? would it be a direct bolt-up? i was planing on going to the junk yard and trying to find a dual fan setup. thanks, tom
Old Jul 7, 2002 | 07:31 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
you'll need the upper and lower fan mounts and the fans themselves.i've got mine wired to arelay with a toggle switch.
Old Jul 7, 2002 | 08:00 PM
mckenzie's Avatar
great, can you tell me how you wired it? thanks, tom
Old Jul 8, 2002 | 12:34 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i got the upper mount for sale; check sig
Old Jul 8, 2002 | 06:35 PM
craig's Avatar
Car: 86 camaro
i ran a #10 awg wire fused at 30 amps from the battery[in the trunk]up to the dash.i pigtailed the wire at the dash where i installed the switch , to power the switch and continued the #10 and a #16 to the relay. the #16 gauge will operate the relay and the 10 goes thru the normally open contact to the fans. the other terminal on the fan goes to a good ground. hope this makes sense to you
Old Jul 8, 2002 | 10:02 PM
Desert86Roc's Avatar
Check out http://www.metzlerracing.com/dualfans.htm
Old Jul 9, 2002 | 05:37 AM
mckenzie's Avatar
thanks for all your help!:hail: Tom
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
