TWO transmission coolers?
Old Jul 8, 2002 | 12:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
right now i run through the cooler in the radiator and then the b&m. its the largest b&m street cooler. would it help any if i put another b&m in there? is it necessary? i am just tossing ideas around here and trying to figure out how it would run.
thanks
brady
Old Jul 8, 2002 | 02:11 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I'd say bypass the radiator cooler altogether. My tranny temp never gets within 30 degrees of my coolant temp, so all you're doing is heating up the tranny fluid. I have a B&M 24000 GVW cooler, and my tranny temp is usually 150, maybe 175 in traffic. My coolant is a steady 205, and my engine oil gets up to 220.
Old Jul 10, 2002 | 06:18 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I would reccomend jsut using the single B&M and bypassing the in-radiator cooler. When the tranny fluid goes into the radiator, it will only cool down to the temperature of the engine coolant which is surrounding it. With a completely external cooler, it can actually get cooler than the engine coolant.
Old Jul 10, 2002 | 09:01 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Don't forget you don't want the tranny TOO cold or you'll hurt it just like you don't want it too hot. Best thing is to run it through the tranny cooler then through the radiator tranny cooler to heat it back up.
Old Jul 10, 2002 | 09:47 AM
you arent running it through the radiator?
Old Jul 10, 2002 | 10:05 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Mine is only running through the trans cooler, its not going thru the radiator. The other reason I did this is because my last tranny spit out alot of metal shavings when it blew and I did not want them going into the new trans from the radiator.
Old Jul 10, 2002 | 10:36 AM
so my B&M 24,000 GVW cooler is enough? i would of thought it needed more...
thanks
Old Jul 10, 2002 | 11:55 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I have a griffin radiator, it doesn't have provisions for tranny cooling.
Old Jul 10, 2002 | 08:03 PM
does anybody know the transmission temperature in completely 100% bone stock form. on a car just running the ATF through the radiator
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
apie2546
Sep 20, 2015 01:03 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
