A/C cooling problems
Old Jul 13, 2002 | 04:08 AM
Maro's Avatar
Hi there,
Just got my A/C fixed (compressor blown), and got everything together when the hot weather hit, but I've run into another difficulty. It seems that when I use my A/C, fans come on, and keep running, so that rules out the fan relay, but the heat builds up enough that my speedometer stops working (85 Camaro Berlinetta, Digital dash, 2.8 V-6). Problem is, when I don't use that A/C, the car doesn't overheat, and the speedometer doesn't go out. Also, the fans come on as normal as well with the A/C off.
Any reccomendations?.... still trying to puzzle this one out, Fan switch?.... new Fan?.... air dam is on, 50/50 coolant, and this problem didn't start until my A/C died.
Thanks in advance.
Old Jul 14, 2002 | 01:34 PM
MdFormula350's Avatar
that sounds very weird, i am not too familar with digital guages and therefire all i can say is to run a search on the boards.
Old Jul 14, 2002 | 10:32 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The fan(s) is(are) suppposed to come on with the A/C, that's normal.
The digital dash part.. (this is only a wild guess) might be caused by a weak alternator.
When the fans come on & the compressor is running, the voltage might be dropping as the alt get hot, just enough that the dash turns off (assuming the dig. dash has to stay with X voltage to stay on). It's an 'out on a limb' guess but, I don't know squat about dig. dashes.
Old Jul 16, 2002 | 04:34 PM
AggieZ28's Avatar
My interior lights used to go out when i turned on my headlights at night. Goodyear ran a test and said it was something in the instrument panel.
if you have a good sound system , it might be over working your alternator. good luck.
Old Jul 18, 2002 | 04:00 AM
Maro's Avatar
Well, after trying out a few things, (new rad cap, fan motor, and ducting more air into the rad by channeling the airflow through the airdam), I was able to get my temps a little lower.
However, my speedometer still goes out. Checked with a place I know that only fixes sensors, seems that the VSS controls input from the tranny to the speedometer, so it's either fried, or it has heat sensitivity in the high temps we are currently experiencing. I'm getting the tranny flushed and serviced this morning, and the VSS sensor changed. I'll also get them to look at the wiring in case it's stripped or burned (who knows what it has touched down there).
I'll let you know how it goes.
chazman
Aug 28, 2018 03:25 PM
greenyone
Aug 29, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
BikeFarm
Aug 11, 2015 11:35 PM
