aftermarket fans? trying to keep car cool in traffic
Old Jul 14, 2002 | 05:11 PM
camaroguy99's Avatar
Hey,
I've been having trouble keeping the engine temp down especially in this 90+ weather we're having. I have to sit in traffic about an hour each day, and I find myself constantly watching the temp gauge. I need to find an aftermarket fan assembly to replace my single fan setup. Is there any company that makes a bolt in dual fan setup for a 91 TPI setup w/AC? I see universal fit stuff all over the place but I would rather not deal with trying to make it fit. Thanks.
Sincerely,
Jim
Old Jul 14, 2002 | 08:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
at what temp does your fan come on?
Old Jul 14, 2002 | 11:49 PM
I have it on a manual switch and I turn it on as soon as I start the car.
Old Jul 15, 2002 | 06:12 PM
there are no high flow replacements, you can do a dual fan swap. that or try to find a place to rebuild the motor in your stock electric motor. it will pull more amps but it would also pull more air
Old Jul 15, 2002 | 07:45 PM
I've had real bad luck trying to find a dual fan setup. I'll check the classifieds though, thanks.
Jim
Old Jul 15, 2002 | 08:01 PM
Desert86Roc's Avatar
3rd Gen dual fan setup: www.metzlerracing.com/dualfans.htm Most of the parts can be had at a junkyard or 3rd gen parts website, but if you have to buy some at the dealer, here is the info you need.
Old Jul 15, 2002 | 08:33 PM
Thanks!!
RazorN8
Jan 7, 2022 11:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
zeitghaist
Aug 18, 2015 07:33 AM
Leggman1
Aug 6, 2015 04:15 AM
