Temp Switch on Intake Manifold?
Old Jul 15, 2002 | 10:10 AM
BoulderCamaro's Avatar
OK so I know that the fan switch is supposed to be between cylinder 6 and 8 but I'm blind and I can't see mine, even from the bottom... Yes I've gone in from the bottom and the top...
Anyway there looks like a there is a temp sensor on the top of the block on the intake manifold towards the front of the car slightly offset from the center towards the passenger side.
Anyway I didn't take that sensor out because there is a plastic adaptor piece piece that I couldn't remove from the mystery sensor so I just left it there.
Could this be the fan switch or do I just need to become not blind and find it between 6 and 8? In any event will there be an adaptor around the fan switch or will I just pop off the piece with green/dark green wires unscrew the bad fan switch and presto or is it more complicated.
Thank You!
Old Jul 15, 2002 | 11:37 AM
NEVER MIND!!!
Figured it out this is the CTS...
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
