Napa fan switch doesn't work.
Old Jul 17, 2002 | 10:27 PM
Z28ROC's Avatar
well I bought the buick low temp fan switch from Napa. Anyway I hooked it all up and started the car. The fans came on right around 210 or so. But since then they've never shut off! They come on as soon as I turn the key. For some reason the thing is constantly grounded. And obviously not working.
My question is, has anyone dealt with this before? I trced the wire and made sure it's not burnt and grounding on something. I used teflon tape on the sensor, could that possibly cause a problem? Or is this just a case of a bad fan switch?
Old Jul 18, 2002 | 01:59 AM
1a12's Avatar
if i remember correctly, you don't use the teflon tape, otherwise the sensor won't have a ground connection. it may have a small connection, but you want all the connection you can get.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
dyeager535
Aug 28, 2015 08:10 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
