Question on water pump bolts
Old Jul 18, 2002 | 11:07 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I'm replacing my water pump tomorrow and wanted to know if the Drivers side bottom bolt is the only bolt that gets sealed because it goes through the water jacket? Also, do any others need to get sealed? What kind of sealer works the best, I've read that Permatex 300 is good but, don't use any silicone type because it eventually wears out.
Old Jul 19, 2002 | 06:09 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
We've always gooped all 4 just because, as far as sealant-whatever was laying around, sometimes the permatex blue, and when I did my motor rebuild I used permtex black cause it was there, no leaks thus far.
Old Jul 19, 2002 | 05:59 PM
mckenzie's Avatar
hello, i use liquid teflon (white liquid in a squeeze bottle) i coat all four bolts. best of luck, tom
Old Jul 20, 2002 | 12:47 PM
GKK's Avatar
GKK
Thanks guys, I used "Permatex" Water pump and Thermostat Housing RTV silicone sealant on all four bolts even though the drivers side bottom bolt is the only one that goes through the water jacket (found that out when I removed that bolt and coolant seaped out). I decided to coat all four bolts because after I removed the bolts I saw some factory sealant on each bolt. I thought, since the factory put sealant on each bolt, I should do the same.
eightsixseven
Dec 16, 2024 01:50 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
