Leaking lower radiator hose at water pump end
Old Jul 21, 2002 | 09:52 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
I noticed that my car was leaking coolant where the lower radiator hose connects to the water pump. The coolant seems to seep around the edge of the connection and drips down the hose. I replaced the hose today and it's still doing this... could there be a crack or something on the water pump fitting that would cause this?
Old Jul 22, 2002 | 12:46 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
It's leaking from underneath the water pump from the weep hole. See my post on this board for a picture of the water pump I just replaced. the post is called "pictures of my stewart waterpump install.
Old Jul 22, 2002 | 09:08 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
GKK, I checked out your post... how would I go about fixing this? Would I need a new water pump, or could I just plug up that hole?
Old Jul 22, 2002 | 09:12 AM
GKK's Avatar
GKK
Yes, you have to replace the waterpump. Coolant leaks from that hole to tell you that the water pump shaft seals are bad.
Old Jul 22, 2002 | 09:19 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Thanks so much... your help saved me a lot of potential headaches!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
