95 4.3 ltr. water pump
Old Jul 29, 2002 | 10:14 AM
89 red RS's Avatar
I know this isn't a camaro but i am going to try to change the water pump on my friends 95 blazer its a 4.3 ltr.
and I need a front view pic of one if anybody has one so i can see how the belt is put on...
also is the installation of the water pump pretty straight forward like our camaros are?!!!!
thanks any help is appreciated as always
Old Jul 29, 2002 | 08:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
it will be the same deal as changing one on your camaro but, in addition to having the pump, you will also have to deal with the belt driven fan thats driven off the w. pump pulley. If im not mistaken it also uses the same pump that our sbc v8's use. I have an s-10 as well and Id post a pic but my camara isnt doing to hot and its dark out. There should be a small sticker w/ a diagram of the belt line there on the rad. support to show how the belt is routed.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
