Car leaks Anti-Freeze
Old Aug 3, 2002 | 07:20 PM
REBIRTH's Avatar
I have a leak coming from the main hose on the left of the Radiator. It doesn't look cracked or peeling. Any idea's?
Old Aug 3, 2002 | 08:38 PM
breathment's Avatar
well u might be better off taking it apart and looking at it, there might be something that u aren't seeing...
Old Aug 3, 2002 | 10:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A bad water pump will leak out of its bearing's vent hole as it progresses theough the stages of death, which will run down the hose and drip off.... You'll be buying a water pump real soon.
Old Aug 3, 2002 | 11:28 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
It's leaking from this weep hole on the bottom of the water pump.
Old Aug 4, 2002 | 11:34 AM
REBIRTH's Avatar
I'll check out the Water Pump. It will only leak when the Engine is hot. If you take it a couple blocks, it won't leak.
I'll take it apart today and check it out.
Thanks!
Old Aug 4, 2002 | 11:40 AM
REBIRTH's Avatar
The Fluid isn't leaking from the Water Pump body, it's leaking from where the hose connects to the Radiator. Is that another sign of a Water Pump failure?
Old Aug 4, 2002 | 02:00 PM
breathment's Avatar
it might be leaking from the waterpump and just dripping down the side to the hose. but u should replace the lower hose anyways just to be safe.
Old Aug 4, 2002 | 06:45 PM
REBIRTH's Avatar
I found the problem. The Hose from the Radiator to the Water Pump has a hole in it from the Air Compressor spinning when I was running the Air a few weeks back.
I heard some hissing, so I pulled over and saw the water shooting small amounts of water against the Air Compressor, which then leaks on the ground.
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
