Thermostat
Old Aug 8, 2002 | 05:43 PM
String's Avatar
Thermostat
My car just overheated and i have no clue why, wasn't hot out. not in much traffic, radiator was filled with coolant. Told Stat might be stuck and t get a new one. what kind should i get, car runs aroud 220 right now but wouldn't it be better to get a lower stat.
305 TBI 89 RS
Old Aug 9, 2002 | 11:44 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
180 with a couple 1/8" holes in the housing
Old Aug 9, 2002 | 03:01 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
my friends 92 rs was heatin up bad too, he couldnt figure out y..i told him to give me 4 dollars he did and i went bought a 195 drilled 3 small holes in it and dropped it in...he was at work when i did this....now he thinks im a genius which isnt true he just isnt very bright lol his car never goes 210 now
Old Aug 9, 2002 | 04:42 PM
String's Avatar
well, i did figure out what the problem was. The Fan won't come on anymore so for now i have to drive around with the air on to bypass the relay and turn the fan on. Im assuming it's either a bad relay or sending unit in the Rad. Still would like to get a new thermostat though.
Old Aug 10, 2002 | 08:40 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
AC on does not bypass the relay, it only gives it another method to turn on. The fan switch is located on the pass side block between cyl's 6-8. It has a single wire to it. Grounding that wire with key on engine off should turn on the fan. That confirms all wiring and the relay are working. Since the fan runs with AC then you can be pretty sure it's a bad fan control switch or perhaps the wire simply came off. The fan relays are notorious for being intermittent. With the AC on and fan running give it a couple of taps with a screwdriver handle. Also wiggle the fan relay connector as they can also be a problem.
Old Aug 10, 2002 | 10:24 PM
String's Avatar
problem fixed
well, i figured out it was a bad relay. Got it replace today and it all works fine and good like normal. now its time to get a new stat.....heh. Thanks all for the help.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
