removing AC W/duel fans
Old Aug 11, 2002 | 11:28 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I have removed my AC. Is there a way to make the second fan come on in conjunction with the first? Can I just use the green lead from the pressure switch on the AC and wire it to the other fans temp switch?
Old Aug 11, 2002 | 03:00 PM
breathment's Avatar
hmm, you can wire both ground wires coming from the relays together, they should easily be able to handle the extra current. however it might be a large pull on ur charing system having both fans cut on at the same time..
Attached Thumbnails removing AC W/duel fans-fandiag.jpg
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
