Aftermarket Temp Gauge
Old Aug 13, 2002 | 07:41 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
I want to install an aftermarket temp gauge and am wondering where the best place to put the temp sensor. Am currently looking at mechanical gauges, and will be hooked up to a 305 TPI ('86 IROC).
TIA
James
Old Aug 13, 2002 | 08:45 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I put in an Autometer 2-1/16" mechanical gage earlier this year, mounted in the A-piller gage pod. I put the sensor in the front of the intake manifold, where the cold-start injector switch USED to be. This location is right next to the engine coolant sensor, so your gage should read real close to what the ECM sees.
Mine does, works great, looks good. May have a picture of it.
One word of caution, the supplied 6ft cable barely reaches the intake manifold, so must use care when routing the cable. IE don't make sharp bends.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
