coolant leak
Old Aug 17, 2002 | 05:21 PM
mrbboy's Avatar
NEED HELP ASAP!! COOLANT LEAK
i just noticed that there is coolant at the driver side of the intake manifold bottom just above the front of the cylinder. Is it possible to have a leak in this location? How hard is it to replace the manifold gasket? What do I need to get to do this repair?
91 RS TBI
Old Aug 18, 2002 | 12:24 PM
mrbboy's Avatar
Anyone?
Old Aug 18, 2002 | 12:31 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
could either be a leaky stat gasket, or the manifold gasket. My manifold gasket was leaking and had a mechanic do it. That cost me $500.
If its near the stat, I'd start there (much cheaper) and if its not the gasket at the stat, it could be that your water housing is warped where it sits on top of the stat. I
Old Aug 18, 2002 | 03:52 PM
mrbboy's Avatar
Okay, I started to remove things but I have one question. It says in the manual that I have to remove the TBI, EGR and distributor. I don't see why I have to remove the TBI and EGR. Can I just remove the vacuum hoses attached but keep them on the manifold then remove the manifold with them on top? The distributor would still need to be removed.
Old Aug 18, 2002 | 05:49 PM
mrbboy's Avatar
One last thing to remove, the distributor. Any precautions or things to be careful about and to watch out for before or during the removal?
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
