checkin a/c system for leaks?
Old Aug 20, 2002 | 12:12 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys i just swapped my engine and i had my a/c out and there was not a drope of anythiugn in the lines when i disconnected it. now that i put it all back together is there a way i can have it tested for leaks or that my compressor is good cause i don;t wunna spend the money on the r134 coversion kit and fill it up only to have it leak out in a week. thanks
Old Aug 24, 2002 | 07:52 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
DON"T USE 134a you will be sorry you did. USE R-12 or R-414B those two work the best in our camaros. Well the easiest way is to just PULL a vacum, turn off the gauges and let it stand over night and see if it will hold a VACUM. Make sure you check your gauges with the vacum test first and use a strong vacum pump. You only need to pull vacum for 5 min then let it stand over night. If it doesn't hold, you will need to get some die and find the leak. Also MAKE SURE YOU HAVE the right amount of refergerant lubercation in the system, you will have to add it into the back of the compressor ports. Also change your dryer (the big silver can thing by the fire wall)
92projectcamaro
Jan 18, 2016 08:00 AM
Slush92RS
Sep 2, 2015 08:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
zayne0
Aug 24, 2015 07:22 PM
