not your normal cooling problem
Old Aug 20, 2002 | 11:15 PM
thesasquach's Avatar
i asked this a while back in the trans section ....... i have a '91 RS 305 TBI with a five speed ...... i have a lot of heat coming from my console around the shifter from the parking break handel the ash tray even gets very hott ( like 150 to 200 degrees) and it burns my right leg ...... i removed the shifter plate and i can see the top of the trans is there soposed to be some kind of insulation or some sort of cove there that is missing ? maby someone has an idea if not?
thanks for any help you may have David
Old Aug 21, 2002 | 05:29 PM
86IROCZ's Avatar
There's supposed to be a rubber boot there. You should not be able to see your transmission through your center console (unless the boot's not there)
Old Aug 22, 2002 | 12:04 AM
i take it you mean a rubber boot that ataches to the floor pan under the console? if so then no i dont have one. after removing the cover on the console that the shifter boot is atached to you can look on tru to the trans i thank you for your help i feel a trip to the dealer is in my future. David
Old Aug 22, 2002 | 09:17 AM
MdFormula350's Avatar
yeah sounds like your definitely missing something!!
my brothers car is a manual tranny and he had a nice thick rubber boot and some insulation to keep the heat out..
good luck..
chazman
Aug 28, 2018 03:25 PM
Prodigious
Oct 4, 2015 11:20 PM
fbirdroller
Sep 2, 2015 10:27 PM
chazman
Aug 22, 2015 02:01 PM
mustangman65_79
Aug 8, 2015 12:07 PM
