Duh, Water Pump Question??? READ ME
Old Sep 6, 2002 | 04:49 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Ok, I have of course an 87 IROC-Z with a nice rebuilt 305 and a super ram goin gon it and some new heads, but before all that crap goes on, I need to put the engine back together so I can drive it out of the back yard.
I need a new water pump and I'm not sure what to get, long or short style and what is reverse rotation?
I need one that will work with my stupid v-belts, I am going to keep them since I'm removing the A/C.
Old Sep 6, 2002 | 07:08 PM
PONTIACGTA1988's Avatar
go to www.jegs.com or summit.com you'll find what you need..if you have money get an aluminum pump...if your broke like your handle says..then do what i did..i bought an impeller which you rivet to the back of your original water pump..if you have your original pump you can do it..its about 5 bucks for that impeller...so your call
Old Sep 6, 2002 | 07:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Should be long style, standard rotation. Belt setup shouldn't matter, the pump doesn't come with a pulley on it.
Old Sep 6, 2002 | 10:11 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Reverse Rotation just means that the Crankshaft and Waterpump rotate in opposite directions as in the case of a Serpentine belt setup. In a V-belt setup both the Crankshaft and the Waterpump rotate in the same direction.
Old Sep 8, 2002 | 04:09 PM
thats what i needed to know, i was buying one from jegs anyhow.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
