heater water control valve.....
Old Sep 29, 2002 | 09:57 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i have an 88 camaro sc, and am trying to eliminate some things under the hood, and heres a couple questions: what is the purpose of the heater vacuum operated water control valve in the engine compartment? can it be removed without any side effects?
Old Sep 29, 2002 | 10:23 PM
ctandc's Avatar
This valve is just what it implies......heater control.
The valve should have a vacuum line that runs to your heat / AC controls inside the car.
When you turn the heat on, the valve opens, letting hot water circulate through your heater core, and thus you have heat in your car.
When you have the heat off, this keeps water from circulating through your heater core, and keeps the heat from entering the car.
The previous owner deleted this in my IROC, and my feet get quite warm......I plan on installing another one this spring...
HTH
Chris
85 IROC
Old Sep 30, 2002 | 03:18 PM
scott's85T/A's Avatar
I just bought a new one for my 88 camaro but don't know exactlly where it goes..Anyone got a pic of one on a car?My T/A dosn't have one eather but if it works on the camaro I think I might go get another one.I feel the heat too.
Old Sep 30, 2002 | 03:47 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Heater valve and pipes pix
Here is a pic of the heater valve and pipe routing. Please note that the valve is upside down in the picture.
Hope this helps.
Andy.
Old Sep 30, 2002 | 03:50 PM
Car: 91 camaro rs
Forgot to put words on!
You can just about see the pipe routing.
Andy.
Old Sep 30, 2002 | 06:13 PM
Thanks for the pic,but I still have one quick question,,I am guessing that the other heater line that you have sitting up near the radiator goes to the water pump?
Old Sep 30, 2002 | 09:00 PM
ctandc's Avatar
On a stock F-Body ( TPI anyway )... two water lines come from the firewall ( heater core )
One runs to the radiator to the pass side tank. The other line normally runs to the heater control valve, then from there to the throttle body on , then exits the throttle body on the driver's side and loops down with a short hose to the front of the intake manifold.
When you do the throttle body coolant bypass mod ( keeps the throttle body cooler without hot coolant running through it ) The hose would run from the heater core, to the control valve, then to the fitting on the front of the intake right above the coolant temp sensor.
HTH
Chris
85 IROC
Old Sep 30, 2002 | 09:42 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Unless you are me and your core blew up so you had to bypass it
Old Oct 1, 2002 | 10:22 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
wouldnt the air temperature control door control the heat inside the car?
Old Oct 1, 2002 | 10:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
HTH
Chris
85 IROC
i deleted mine and noticed no increase in temps. i dont have AC, and the windows stay down so
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
buckshot63
Sep 10, 2015 09:15 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
