Fan Question
Old Sep 30, 2002 | 12:25 AM
NOCANDO's Avatar
Fan Question
Ever since I had my AC converted to the new R34, my fan stays on everytime I have the AC on. Today while driving, my temperature shot up to red. I turned on my AC and noted the fan not working. I pulled on the wire harness connected to the fan motor and the fan turned on. I drove back home and inspected the wire harness. I discovered that the connector to the fan motor had melted a bit. I pulled it off the fan motor and cleaned out the connector and reconnected it. The fan now works fine for now. My question is....is that a sign that my motor is burning out, or is there another problem that the connector almost melted out.
Old Sep 30, 2002 | 01:43 AM
MadMax350's Avatar
Car: 1987 Pontiac Fiero
Engine: 3800 Series 2 Turbo
Transmission: 4T60-E
Axle/Gears: 3.33
Sounds like it could be one of two things going on; either your cooling fan motor is pulling too much amperage (signalling a motor going bad) or the electrical connector has high resistance (dirty, broken wires, etc). Run the cooling fan for a while and then shut the car off and unplug the connector and see if it is still getting hot. Sounds like it might have just been dirty.
Old Sep 30, 2002 | 09:14 PM
NOCANDO's Avatar
Thanks for the tip...I'll try it out.
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
