air dam supports - just got em
Old Nov 9, 2002 | 09:53 AM
  #51
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I have an airdam (factory) but my car still gets to 235 on the highway. what now? Stays perfectly cool around town (170~)
Old Nov 15, 2002 | 02:44 PM
  #52
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
235* is within specs...
I basically did the same thing as the one with the holes... I got some angle brackets from Home Depot and bent them also back on themselves so that it holds the deflector just forward of vertical, and when I manage to scrape bottom they will give. Just means I have to reach under the front end and pull the deflector back forward every now and then.
Now to get a 350 and drop it in there... the 305 is only running on 6 cyls now.
Old Nov 15, 2002 | 05:54 PM
  #53
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>I have an airdam (factory) but my car still gets to 235 on the highway</b>
Not for me. I have a Be cool/stewart/dual flex fans...
Also i have a blower
Old Nov 15, 2002 | 06:02 PM
  #54
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
if your car is hitting 235 on the freeway see if you are running lean and check your thermostat
Old Nov 16, 2002 | 08:34 PM
  #55
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
eh
<b>if your car is hitting 235 on the freeway see if you are running lean and check your thermostat
</b>
Good points,
I have no thermostat, i tried with and without however.
I was running lean, but i richened it up and it still does it. PLugs are usually a little too black for my taste...
Timing? I have no vacuum advance, and my total is 34*. I tried 38* and 32* total nothing helped.... I have a feeling its somthing deeper and more important.
Old Nov 23, 2002 | 01:47 AM
  #56
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
what does the airdam do? i took mine off becuase i thought that it wasnt important. should i put it back on? i havent noticed any overheating (except recently cuz my fan stopped working). any thoughts?
Old Nov 30, 2002 | 11:25 PM
  #57
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
The air dam forces air into the radiator. After 35 mph the fan shuts off so the only air coming into the radiator is brought in by the dam. Now some cars can get by with no air dam. I have for almost a year now and I finally picked one up tonight to install. I run a 160* thermostat though. I did notice in the summer heat, which you know what it was like here during the summer since you aren't too far from me, my car was approaching 220 even with the 160* thermo. My advice for you is to put it back on. The car does need it.
By the way brody, where the hell are those after pictures
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
