just got my air dam supports gonna mount em up hopefully monday. they are stainless steel, and they wont bend no matter what at the temps they will see.
another
those look pretty sweet.... I wanna see some install pics
they will be in this thread
Quote:
Originally posted by z28_dave
stop wasting board space with bracket pictures
who the *** are you??? stop wasting space with your damn usless postsOriginally posted by z28_dave
He's from Tokyo. Do they even have Camaro's over there?
Brackets look plenty strong enough...let's see them installed.
they got a bunch of riceOriginally posted by PhilM
we have snow over hereOriginally posted by PhilM
lmao.Originally posted by z28_dave
stop telling people who have almost 2000 post on this board to stop wasting space.
-fly
Quote:
Originally posted by fly351
lmao.
-fly
can i tell u since you only have 100?Originally posted by fly351
lmao.
-fly
What's your problem? Those brackets are useful information because all our cars have air dams (or should) and he is showing us how he is setting up his. This might be a very good idea for those who lost their air dam and they might want to try his way of doing it. So why don't you just chill out a little. GeezOriginally posted by z28_dave
Quote:
Yeah! Originally posted by trans87
Looks nice!
Didn't we Bomb the **** out of Tokyo??
They look sweet, how are you going to install them? I had a metal dam made, should be on this weekend, I will have pics and what size it is.
Quote:
Originally posted by Dirk
Yeah!
oooooooooooooooooooooooooooooooooooooooo Dirk with a non tech postOriginally posted by Dirk
Yeah!
thats a :nono:
you are gonna get in trouble
i am going to get longer screws/bolts for it. and use the stock air dam for now. although i could easily just buy a sheet of metal and use that. my car is going to the shop so....... it might be a while Originally posted by 88Bravo
So you are going to drill holes in the metal. Those should help, just becarefull where you park, it will connect to your core support!!
yeah careful level will be going up a bit. holes are going to be drilled in them pretty soon.Originally posted by 88Bravo
Quote:
thats a :nono:
thats a :nono:
whoa dirk beat me to it!! but seriously guys, i don't wanna close this thread due to a couple bad apples, and waste even more server space...
Uhhh we have airdams on our cars? Originally posted by trans87
I don't think we do, that is why I had one custom made and I am going to try to make it work. I heard it does!!
Quote:
you are a weirdoOriginally posted by iroc22
and what makes you think that mr mod. dont waste space you are supposed to be mature
i don't believe the qualifications for being a moderator include being mature..Originally posted by brodyscamaro
Quote:
lol :crying: i want to be a mod i want to be a mod i want to be a modOriginally posted by breathment
I made brackets out of that adjustable strap stuff that has pre drilled holes in it. I bent them to push the air dam forward and they bend when I scrap, just means I have to go under and push them back into shape.
Sounds like a plan. I'd worry about the supports in the original post being too strong. When the air dam gets bent back on a curb, it could damage the attachment points for the brackets. Also, the ones in the pictures look like they're at 90°. I believe a new air dam is raked slightly forward to be more effective. Mine has taken on a curve over time, raked forward at the top and back at the bottom. There is actually a notch in the reinforcing at each end, allowing it to bend back instead of straining the attachment points at the top.
what is ur problem dude?Originally posted by brodyscamaro
im just joking around, DUDEOriginally posted by breathment
alright man, sorry if i jumped to conclusions or thought u were trying to be an a$$Originally posted by brodyscamaro
thats cool. i was wondering why you jumped my *** like thatOriginally posted by breathment
My computer should be up and going in about two days, so you will have to wait till then to get pics. I installed a metal air dam. But instead of going with a 90* bend I went more of a 75* ish. But to make up for the angle and shortness, I just made the metal longer. But right now I am having an overheating problem!! I think it is my thermo stat, will find out this weekend. I bought a 195*, but for the summer I think I will run a 180*. And luck with the metal straps? Are they installed? Any improvements?
they are not installed. i have been having problems with the car (fuel pump). but now that that is solved it is raining so...Originally posted by 88Bravo
Just because they have a lot of posts doesn't mean those weren't wastes of server space(see: Mark A. Shields)
I didn't know the air dam had some special mounts to make it work, but good job using the right parts for the job!
Quote:
and your point of this wasOriginally posted by rezinn
lol I don't have one either damn body shop took it off and I just realized its goneOriginally posted by iroc22
Body shops will do that! they also will remove the cover that goes from the rad to the nose where the hood latch is and they won't put it back on. Originally posted by trans87
I took my airdamn off myself.
Yea well so far the car runs fine without one. Never goes over 215 and with my stop and go driving most of the time the fan is on and the car runs at 190. I am still going to get one as soon I can find a really cheap one.
Brody, are you going to use those to reinforce the dam from the rear side of it? remember what the dam mounts to. the stock setup if the dam is struck will distort the mounting holes for the fasteners. you might wanna think twice, it's got to have some movement otherwise it's going to rip right out if you hit it.
Quote:
right, right, right you are. which is my i am no longer going to used those. i have the same thing with 1/2" pipe in my garage now. the pipe will reinforce it but bend if necessary. Originally posted by Danno
Wow dirk posted!
Nice job where did you get the brackets from?
Nice job where did you get the brackets from?Senior Member
Well still no pics yet, but it turns out to have been my thermo. It went bad in only one year. Well the 195* is in it with my home made air dam, and on hte highway I have yet to turn on my fan!! By the way if your thermostat locks up in the closed postition, your motor will get to about 240ish!!! No I can do 85 and never worry. Hopefully the pics will be up here by the end of the week.
i so totally want that. i want that so bad! my only question is wouldnt that rub on sume curbs/speed bumps?
Quote:
Yes It does! I built it in two halves, so I can unbolt the bent bottom half, and replace it. Either that or I just bend it forwards a bit more. Doesn't half do the job tho'.Originally posted by HamSpiced
Has anyone tried wiring the airdam to thwe front bumper reinforcement I did that with mine and it works just fine .
