160 T-stat in winter
Old Oct 19, 2002 | 10:14 PM
86IROC350NY's Avatar
Will my heat still work running that low of a T-stat? Or should i put the stock 195 one back in.
--Dan
Old Oct 19, 2002 | 10:42 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
since it takes <5mins i would put the 195 in there
Old Oct 20, 2002 | 12:43 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I never could get much heat when using a 160.
Old Oct 20, 2002 | 08:11 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You will get lukewarm heat at best. A 180 should be decent, however I would agree with Brody and put in a 195. The engine will run the best with a 195 also.
Old Oct 20, 2002 | 01:08 PM
MdFormula350's Avatar
i agree go with the 195, you could using a 180 that could be used year around..
Old Oct 20, 2002 | 01:37 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I've tried 160 in winters before worthless for heater... I could breathe on windshield and defrost it faster..... I would go back to the 195 like they said. 160's are just too cold anyways if your running the computer too it won't go into closed loop mode, cause in winter your motor should run a lot cooler since you have a lot of cool dense air going into the radiator.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tmellott89
Oct 14, 2015 02:06 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
meeklay812
Oct 1, 2015 03:46 PM
