Trying to install a Oil Temp Sender
Old Oct 31, 2002 | 07:33 PM
Zombie's Avatar
Hey All,
I am tring to install an Oil Temp Sender. But my mechanic said the one I got wouldnt fit. I puchased the Nordskog "S8013" Oil Temp Sender.
I was reading in other articles of needing an adapter for it. So I was wondering if anyone knew what the exact size might be for this part to put into the hole above the Oil Filter.
Any help would be cool,
Thanks,
Rod
Old Oct 31, 2002 | 07:35 PM
Zombie's Avatar
One more thing
Oh yeah, I have an '88 Camaro with a 350 motor. Thanks.
Old Nov 3, 2002 | 09:24 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I want to know the same thing
Yeah I asked this a few months ago. I have an Autometer sender. When I called Autometer they said it had to go in the pan. I didn't like the idea of drilling a hole in the pan and having a bung welded on since if it didn't work right a pan change on our cars is a major pain. I ended up drilling out the center of a drain plug and pressing the sender in there. Worked great except after I put it in I noticed that it stuck out kinda far so if I hit anything (I've lowered my car) it's gonna take that out. So I'd much rather stick it in the hole above the filter but atleast with the Autometer one, the sender is just a hair smaller and a different thread pitch so it would be some work to have an adapter fit. I hope someone chimes in on this.
Old Aug 16, 2009 | 02:13 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: I want to know the same thing
lmao i know this is an ancient post but i ran into the same problem.
Whats this hole above the filter business?
Old Aug 16, 2009 | 05:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
above the oil filter there is a hole in the block - most f-bodies have an oil pressure sensor there, either the one for the fuel pump, or the combined pump/guage unit.
Old Aug 16, 2009 | 11:39 PM
Zombie's Avatar
Wow this is an old thread. LOL
So yeah, what I remember doing back then was we had a "T" shaped adapter go in the hole there above the oil filter. Then we put the sensors to both ports and all worked great.
Sadly that car of mine stolen and stripped, was sooo much fun. I have another IROC now, but am still fixing it up and not to the point of getting this sensor back on... yet. :-)
Old Aug 16, 2009 | 11:53 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
sweet i'll have to take a look at that tomarrow
Old Aug 16, 2009 | 11:57 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
omg i just realized you were in this post 7 years ago Zombie and you only got 3 posts!!
Old Aug 17, 2009 | 12:12 AM
Zombie's Avatar
Ha ha, yeah, crazy how things go. I just got a notification in my inbox, and i was like oh yeah whats been going on over on these forums. And I could have sworn I posted about more than just this here. Maybe I will get a bit more active, depending on what happens to my current car.
toronto formula
Nov 10, 2015 06:17 AM
NBrehm
Aug 25, 2015 11:49 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
