stewart pump....300 more rpm????
Old Nov 2, 2002 | 11:03 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
I am kind of scratching my head here, any explanations????? I just installed a stewart water pump. connected everything and went out for a drive. I am getting 5300 rpm now till it shifts. whereas before the most i could pull is 5000 rpm no more. Is it possible the pump would of helped this or is it just a fluke??????? no complaints either way ill take a few more rpm any day....
Old Nov 3, 2002 | 11:04 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
I guess that maybe the engine has less load, therefore you are getting a higher RPM with the same throttle pressure, and throttle pressure (blade angle) is the primary factor in how the 700R4 determines shift points
Old Nov 3, 2002 | 11:19 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
kind of the direction i was thinking. just find it hard to believe a water pump could make a difference
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
