electric fan on a carbed 92..
Old Nov 11, 2002 | 01:25 PM
DABE's Avatar
ok...im going to use my stock 92 radiator and single electric fan. Now...i have carbed 350 that is not relying on the computer...so...
how can i wire up the fan so it goes on and off??
how can i get it to come on when i turn on the ac??
I was thinking about buying an aftermarket switch of some sort to turn it on and off...but how can i get it to go on with the AC??
DABE
Old Nov 11, 2002 | 07:34 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I would put a switch on the ground wire of the fan relay which is the green wire I think. Jegs and summit have them that will kick it on when it reaches the desired temp and as for the AC part you can take that same wire and ground it through the AC cooling fan pressure switch.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
64goatman
Sep 9, 2015 01:09 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
rjcme
Sep 5, 2015 01:23 PM
85Special
Sep 3, 2015 04:21 PM
