Mechanical fan size
Subscribe
Nov 12, 2002 | 11:03 PM
Does anyone know the diameter of the mechanical fans that came stock on the early V8 thirdgens? What other vehicles would have a fan with lots of blades that would fit the stock shroud?
Reply 0
Nov 13, 2002 | 11:40 AM
I'm running an 18 inch flex fan in a stock shroud without a problem. I would guess most GM fans that are around 16-18 inch would probably fit. Make sure you get the correct rotation though( I know of someone that ran a fan backwards for quite a while--it worked ok around town).
Reply 0
Nov 13, 2002 | 10:57 PM
That's what, a 7 blade fan? How well does it work for you? I've got the stock 3 blade fan that came on cars without air conditioning. It may have been adequate for a stock LG4 but with my setup now it gets hot alarmingly fast when it sits idling.
Reply 0
Nov 15, 2002 | 07:51 PM
Flex-a-lite 6 blade.
http://www.flex-a-lite.com/auto/flex.htm
Works great, I can run the A/C around town in 100 degree weather and it runs 190.
model 1308
Reply 0
Nov 15, 2002 | 09:59 PM
I might give one a try. Staggered blades would be nice but you can't hear a thing over my exhaust anyway. I like the sound of the 10,000 RPM rating, too many stories about flex-fans throwing blades made me kind of shy away from them.
Reply 0
Nov 17, 2002 | 01:39 PM
I've had a cheapo summit fan toss a blade. Went down through the shroud (lucky). But, that might have been my fault--I bent that blade a few months previous and probably weakened it. It's quieter than my 91 Jimmy's stock fan when the clutch is kicked in.
Reply 0
Nov 17, 2002 | 03:29 PM
What kind of clutch are you using with that, by the way? Might as well replace everything while I'm at it.
Reply 0
Nov 17, 2002 | 08:32 PM
No clutch, aluminum spacer.
Reply 0
Subscribe
