what should i do??
Old Nov 15, 2002 | 11:17 PM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
what should i do??
my car keeps over heating now and its pissin me off. what can i do to prevent it from over heating?
Old Nov 15, 2002 | 11:28 PM
rezinn's Avatar
You could try fixing it.
Old Nov 16, 2002 | 07:10 AM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
I had to buy a cooling temp sensor for my car...you could try that.
Old Nov 16, 2002 | 07:15 AM
Engine: LG4 305
Or if it is an electric fan you can check the cooling fan relay switch.
Old Nov 16, 2002 | 11:42 AM
breathment's Avatar
we need more information!!!!! when does the car overheat, how hot does it get, how often does it occur.. what kinda car do u have, what kinda cooling system. etc etc.. we need details..
Old Nov 16, 2002 | 11:26 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
its an 87 ta and its stock except for the exhaust. it happens everytime i drive the car.
Old Nov 17, 2002 | 01:33 AM
Benny's Avatar
Give us some symtoms or something to work on, With the info you gave us, I ask the following questions:
1. Check flow of your water pump, take the radiator cap off (cold of course) and check for flow when the therostat opens.
2. Does it have a thermostat? Is it blocked? Have you replaced it lately?
3. Air Dam?
4. Check operation of your electric fan(s).
5. Condition of radiator, Leaks?
6. Does it overheat to a boil over or does the guage just get high?
7. Water temperature sender/sensor.
8. Do you hear any bearing noise from your water pump?
Turn on your A/C, does your fan(s) come on?, Is there any visible leaks or do you smell anti-freeze?
Sometimes it is as easy as a non working therostat, but with cooling there are many variables.
Tell us how long from start up to overheat/boil over.
Old Nov 17, 2002 | 08:39 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
the thermostat works... and when i drive it within 15 min. its boiling over and then i have no antifreeze in the radiator. i checked for leaks and i didnt see any.
