air in the system
air in the system
i have a 87 iroc tpi and the oil pressure drops dramaticly when the water temp goes up and the oil pressure drops even more when i put the car into a gear, I was told by danno to bleed the air out of my system, but there is only one problem, i don't know how to do that. If any could tell me how to bleed the air out of the system it would be greatly appreciated, thanks
the radiator cap is the highest point on ur cooling system. so after running ur car for a few heat up\cool down cycles. all the air should make its way up to ur radiator cap and out. if u pull off ur cap and there is water all the way up to the top. then air isn't ur problem..
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i foudn that the absolute best way to do this without burnign the s**t outta your hand is to buy a new radiator cap that has the little lever on it that u can lift up to let some stuff escape.. it sliek 6 bucks and i think the one i bought was 16lbs.
Car: "02 z-28
Engine: LS-1
Re: air in the system
