Stock 305 Radiator compatible with new 350?
Old Nov 29, 2002 | 08:32 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Will my 1991 RS 305 TBI Radiator/Fan be sufficient to handle the likings of a built up 350, or is that yet another thing I have to get before I do this swap?
Old Nov 30, 2002 | 07:36 AM
Z28DJP1987's Avatar
Made the swap from a 305 TPI to a Crate 350 TPI with no changes to the cooling system or fans. (new chip turns one fan on below 35MPH). No cooling problems with the stock system.
Old Nov 30, 2002 | 08:21 AM
camarokev400's Avatar
I swapped out my 305 for my 406 small block with no problems at all, i run 180 out in the country and about 200 around town, i have a flex fan with no shroud so it would be even cooler if i had the correct shroud.
Old Nov 30, 2002 | 08:58 AM
MdFormula350's Avatar
yup, should be fine!
Old Dec 1, 2002 | 11:43 PM
midnightcamaro's Avatar
how much hp is the 350 ur talkin about i had a 305 TBI in my car and i put a 355 motor in it and i had to upgrade to a Griffin universal alum. radiator. but im using the stock fan. my car would try to over heat just driving halfway across town. and its a small town. but i got the alum. 2 core with the 1 inch tubes universal racing 31x19 and works just fine. barely any modifing was needed for factory fan cover and all. and for all the money saved from buyin one for that car its worth it. it cools like a champ. actually right now runnin to cold.
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
