coolant leak
Old Dec 4, 2002 | 01:50 AM
gerry's Avatar
coolant leak
I own a 1989 iroc that has a coolant leak. I just want to verify if the leak is coming from the heater core. There is a leak coming from the back of the engine near the cat and also in the passenger side of the car. The leak inside the car is coming from the bottom of the dash, next to the center console. My question is, where excatly is the heater core? Is it located where the leak is coming from or is it on the right hand kickpanel? Or could this be a hose that is leaking?
Thanks,
Gerry
PS Any help would be appreciated.
Old Dec 4, 2002 | 01:56 AM
kingrobert's Avatar
the heater core is behind the dash on the passenger side
Old Dec 4, 2002 | 01:57 AM
kingrobert's Avatar
also, if you are leaking coolant inside the car, it's most likely the heater core
Old Dec 4, 2002 | 11:50 AM
MdFormula350's Avatar
yeah sounds like the heater core..
https://www.thirdgen.org/newdesign/t...atercore.shtml
Old Dec 6, 2002 | 07:03 PM
gerry's Avatar
coolant leak
Thanks everbody for your help. I eventually bypassed the heater core.
Thanks,
Gerry
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
