If you own an '84, '85 or '86>>
Old Apr 19, 2005 | 08:56 AM
  #51
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
82 Trans Am, 350 w/ carb, dual fans, summit radiator.
hehehehe..... it came with a v-belt fan and a 305.
Old May 6, 2005 | 12:30 PM
  #52
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
HOt, Hot, HOTTER
305 LG4 '86 with electric fan
When I first got the car it overheated, put in a 160 thermo, fan, radiator and new relay, no problems for years. Changed engines and now fan won't come on but everything is hooked and gets electricity. Finally I said screw it and made it manual with a toggle switch. Now I know it's on.
Old May 12, 2005 | 02:34 AM
  #53
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
86 Z28 305 TPI single electric fan
Mine overheated a lot as well, found a good used Modine aluminum radiator at junkyard and installed it, new fan relay harness from dealer, spliced in a Hayden adjustable thermostically controlled relay (with radiator probe) from oreillys for like $20 in parallel with the stock relay at 160* so if the hayden relay doesnt kick on the ecm will power on the fan at 225*, 160* thermostat (drilled bypass holes to allow it to untrap airbubbles at idle). Works pretty good, planning to install a dual fan setup i bought from Ramchargers as soon as i figure out how to wire it up.
Old Jun 7, 2005 | 11:47 AM
  #54
Eighty5's Avatar
Car: 1985 Firebird
Engine: 2.8L
85 Firebird,2.8 v6 (to be swapped soon),1 electric fan.
Old Jun 9, 2005 | 06:24 PM
  #55
evil84z's Avatar
Car: 1984 Z28
Engine: 305 H.O.
1984 Z28 L69 with now re- installed electric fan. My car came (to me) with a ****ty belt driven fan without a shroud. That car overheated until just a month or so ago!( I have owned this beast for over 2 years now!!!) So I decided to get an electric fan and had to hook it up through a toggle switch. I didn't want to deal with knowing if the fan switch was going to kick in or not!! The car came from the factory with a single electric fan. Also, the A/C was ripped out of the car before I purchased it. (along with EVERY piece of emission equipment)
Old Jul 4, 2005 | 02:53 PM
  #56
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
1986 2.8L w/5speed no a/c base model.
Old Jul 16, 2005 | 04:34 PM
  #57
OneGravenKiss's Avatar
Car: 1986 WS6 Pontiac Trans Am
1986 Pontiac Trans Am 305 700R4 and the stock radiator sucks a big fat one! Single fan also but i want to go dual.
Old Aug 9, 2005 | 06:59 AM
  #58
JDud's Avatar
86 IROC, 5.0 TPI, one electric fan (one broken fan relay)
Old Aug 13, 2005 | 04:13 PM
  #59
bigdaddyvu's Avatar
Car: 84 T/A, 87 iroc-z, 86 turbo z-28.
Engine: 5.7, 5.7, 6.6
Transmission: t-5, 700r4,manual shift th350
Axle/Gears: 3.73, 3.52, 3.23
84 T/A 5.0 H.O. 1 electric fan. Now i have put 2 pusher aux. fan on AC condenser totaling 3 fans.
Old Aug 18, 2005 | 10:59 PM
  #60
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
1984 Firebird SE
Single Belt Driven Fan
Old Aug 22, 2005 | 02:05 PM
  #61
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
84 z28
originally a 305ci w/ v-belt fan.
Old Sep 5, 2005 | 12:27 PM
  #62
silverbullet86's Avatar
Car: 86 trans am
Engine: 305 tpi
Axle/Gears: 3.27 9 bolt posi
1986 Trans Am 305 tpi with single electric fan.
Old Sep 13, 2005 | 01:07 PM
  #63
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
84 z28 305h.o. single eletric fan
Old Oct 24, 2005 | 08:05 PM
  #64
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
link is bad!!!
85 iroc tpi single electric
Old Nov 3, 2005 | 02:47 PM
  #65
blackta6's Avatar
Car: 1986 T/A
I own an '86 T/A with a 305 TPI. It currently has a single electric fan.
The most interesting thing is that the mount used on my T/A is the same mount used in my '83 Chevy X-11 Citation. I figured there would be a shroud in the T/A.
Old Nov 4, 2005 | 06:00 PM
  #66
maroguy1's Avatar
Do you have any pics of that x-11?? did you do anything to the 2.8 Always liked those cars but they never lasted very long the bodies always rot out up here
Old Nov 5, 2005 | 09:06 AM
  #67
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
'84 T/A...L69 = Electric Fan (single)
that's not currently turning on properly (so the car runs just fine at 40mph and above...but if I dip below that for too long the heat guage approaches the red fairly quickly (and boiled my coolant over...gah!)
Sooo...mine might be getting a new fan...perhaps now's the time to install aftermarket dual fans. (Figure it's either the fan or the temp switch that's broken)
Old Dec 8, 2005 | 04:30 PM
  #68
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Originally 84 z L69
Electric fan, works perfect for to cool down after a pass
Old Dec 25, 2005 | 11:33 PM
  #69
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
'82 Firebird, Iron Duke, belt driven fan.
Old Jan 6, 2006 | 03:22 PM
  #70
Cali Z's Avatar
'85 Camaro Z28 built in Van Nuys.
- 305 TPI
- 1 electric fan
Old Mar 20, 2006 | 07:35 PM
  #71
daves12secV6's Avatar
86 iroc 4bbl 305 twin elc fans
Old Mar 26, 2006 | 09:02 PM
  #72
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
'86 305 TPI with 1 single aftermarket fan. Not sure if it had 1 or 2 factory.
Old Mar 27, 2006 | 01:07 PM
  #73
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
'84 Z28 HO (L69), single electric fan.
'84 V6 sport coupe, single belt driven clutch fan.
I dunno what you're trying to find here, but my experience (FWIW) has been that the "high performance" (L69 or TPI) '84-'86 cars got the single electric, while the rest got a belt driven fan.
Old Apr 6, 2006 | 07:07 PM
  #74
TJC8974's Avatar
Car: 85 IROC/First Year Of The "Roc"
Engine: 305........for now
Transmission: 700R4/Corvette Shift Kit
85 IROCZ 305 4barrel carb, belt driven fan, w/clutch
Old Apr 6, 2006 | 07:44 PM
  #75
robmonte's Avatar
Car: 84 Z-28 HO
a/c
Originally Posted by jocww
i got a 84 z and my fan wont go on. i fixed the thing thats on the pass side of the block and i changed the motor in the fan too still doesnt work . at wat temp does the fan go on?
the electric fan runs though the a/c compresser so it needs to be plugged in to complete the circuit
Old Apr 20, 2006 | 09:05 PM
  #76
JKJ454's Avatar
86 TRANS AM LG4 5 SPEED 4BBL. 1 ELECTRIC FAN.
Old Apr 24, 2006 | 04:30 AM
  #77
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
1986 Transam, LG4, single electric
Old May 1, 2006 | 07:06 PM
  #78
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Just picked up another 84 LG4 and it too has a belt driven fan.
Old May 15, 2006 | 09:55 AM
  #79
LadyInRed's Avatar
Car: 1984 Camaro Z28
Engine: 2000 LS1
Axle/Gears: Moser 12 bolt w/4.11's
84z, l69, 5spd, single electric fan.
Old May 31, 2006 | 09:46 AM
  #80
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
91 z28 305 5spd
dual electric fan
Old Jun 1, 2006 | 09:52 PM
  #81
85z28iroc's Avatar
Car: 85 Camaro IROC-Z
Engine: Dual Snorkel 350 Carb
My 85 IROC-Z with a LG4 305 had a thermostatic mechanical fan, with a serpentine belt.
Where is a good place to buy new air dams for under the car?
Is there a better dam available that will send more cool air toward the rad?
Old Jun 3, 2006 | 06:08 PM
  #82
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I got this when clicking on the link in the first post...
Invalid Thread specified. If you followed a valid link, please notify the administrator
I have an 84 Trans Am, L69 with a single electric fan. Normally runs around 195-200 degrees but if I am on the highway at 70mph it runs more around 230-240 or so. I have the Air dam, but I also have the GTA front end which means no additional air is getting to the radiator. Only what the Air Dam can pull through.
I just recently purchased a be-cool radiator and a 160 themostat that I intend to put in this weekend. We'll see if it can make it run a little cooler.
Old Jun 4, 2006 | 02:54 AM
  #83
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
86 Camaro LB9, auto, 1 electric fan.
Ken
Old Jun 19, 2006 | 06:48 PM
  #84
olivesta500's Avatar
Car: 1985 Berlinetta
85 Berlinetta 305 4bbl single v-belt clutch fan
Old Jul 16, 2006 | 11:16 PM
  #85
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
84 Z28, L69, TH700R4, 1 electric fan and a stock HD 3 flu radiator. Never ever ever runs hot. Stock thermostat and driven regularly in 100 degree weather with 90 to 100% humidity.
Old Jul 17, 2006 | 09:00 PM
  #86
robmonte's Avatar
Car: 84 Z-28 HO
some here
I have the same exact everything even the weather and no problems at all
Old Jul 18, 2006 | 01:07 AM
  #87
bigdaddyvu's Avatar
gosh you know this thread started in 12-23-02
Old Jul 18, 2006 | 09:57 PM
  #88
celticages's Avatar
Car: 1986 Camaro Z28
Engine: LG4 305 4 bbl.
Transmission: 5 speed
Fan goes on around 200 degress and shuts off around 180. However...this is a common problem (unfortunately) with these camaros we love. I have the same problem right now and after replacing all of the relays I had to give in and hardwire a toggle switch to my fan to control it manually
Old Jul 29, 2006 | 11:34 PM
  #89
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
i have a 1984 Camaro Z28 LG4, with a fan clutch .. ? is that stock or not
Old Aug 7, 2006 | 06:36 PM
  #90
LordTTK's Avatar
Car: Camaro Z28 -84
Engine: Weiand 144, 350 CSB
Transmission: B&W T-5
-84 z28, 305 carb, belt fan.
Old Sep 16, 2006 | 12:29 AM
  #91
XSVortex's Avatar
85' sport coupe v6 auto, single electric fan
86' IROC-Z28 TPI v8 auto, single electric fan
Old Sep 16, 2006 | 08:08 AM
  #92
Camaroreaper's Avatar
1984 Z28
1984 Z28 LG4 belt driven fan....never overheated....switching ofcourse to the LT1 with dual electic. anybody want the stock radiator of fan pulley message me.
Old Sep 16, 2006 | 08:46 AM
  #93
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
84 firebird
LG4 belt driven
Old Oct 1, 2006 | 08:07 PM
  #94
wrapper8758's Avatar
Car: 1986 trans am, 1985 TRANS AM WS6
Engine: 305 4bbl,305 TPI
Transmission: 700r4,700R4
Axle/Gears: STOCK POSI DISC
fan wont run......tried evrything!!!!!!
fan runs when i turn on ac only......... replaced fan relay ,tested new relay from pontiac svce manual troubleshooting guide....wiring was pretty messed up already from last owner...fan switch on block maybe?.
replaced temp sensor &thermostat too, still overheats and wont run unless ac is on. temp. guage wont work either.......redlines when starting car, then drops below 100 degrees and wont budge..........
any ideas? im going nuts!!!!!
Old Oct 2, 2006 | 07:10 AM
  #95
Ozz1967's Avatar
Car: 1984 Trans Am
IF you get one of those fan switches from Jet that turns your fan on earlier, it will help keep that from happening. I got one for my 84 T/A L69 and it helped keep the temp down below that magic 260 mark. However...in the mountains here of New Mexico, I still over heat really bad going up. So I wound up getting a new Radiator from BECOOL anyway.
Old Oct 2, 2006 | 07:13 AM
  #96
Ozz1967's Avatar
Car: 1984 Trans Am
An update...
I got the new radiator in and working. I LOVE IT! The car warms up now to just over the first hash mark on the temp gauge! When cruising on the Highway it will creep up a little, but never even gets close to the half way mark (What is that, 220*?). I didn't put the 160 thermo stat in because well...I couldn't get the housing off without breaking the bolts so I left the stock 195. I also put a Jet Performance fan sensor in that turns the fan on at 185*. The fan kicks on just about the time the car gets to max operating temp, so I'm running right about 185* or so when the engine is fully warm. I am extremely happy! YAY!
Old Dec 11, 2006 | 09:51 PM
  #97
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
84 Trans-Am L69 H.O 305, single thermo, did these have shrouds? coz mine didn't.
Installed twins out of a wrecked jap car and a custom stainless Air-Dam, she runs at 160 moving to 180 stationary now and that's on a 37'C day with a gutted Thermostat so it would be better with a little more restriction in the flow.
Old Mar 18, 2007 | 09:13 PM
  #98
VenomX-87's Avatar
OLD:
(last post) 1700CFM Dual Thermo Fans out of a Magna V6.
http://i21.photobucket.com/albums/b2...7/OldFan02.jpg
NEW:
New 2700CFM Dual Thermo Fans!
Out of a V8 EL Falcon (Mid 90's Aussie car)
http://i21.photobucket.com/albums/b2...7/NewFan02.jpg
Check out my Blog for more info and wiring setup. http://84transam.blogspot.com
Old Apr 10, 2007 | 03:23 AM
  #99
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: If you own an '84, '85 or '86>>
85 and up camaros came standard with electric fans. If you have an 85 and up with a belt driven fan someone else put it there.
Old May 22, 2007 | 12:02 AM
  #100
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
1986 Z28 305 TPI Single Electric fan.
