new rad needed
Old Dec 23, 2002 | 12:48 PM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
new rad needed
How much of a P.I.T.A is the rad to get out of a camaro, it looks easy enough in the manual.
Any tips for instalation / fitting / bleeding?
Is it worth fitting new hoses and hoseclamps at the same time?
Old Dec 23, 2002 | 07:59 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
On a 91 Camaro RS it is very easy. Just unbolt the electric fan, top plastic cover plate, one bolt from each radiator hold down bracket and hoses. If you have an automatic trans unbolt the two trans cooling tubes. Shouldn't take more than about 15-20 minutes to remove. Also, you might want to change the thermostat while you're at it, just two bolts and a gasket to replace.
Old Dec 23, 2002 | 09:14 PM
MdFormula350's Avatar
as long as the hoses look good i wouldnt replace them.. unless you want to..
i recently changed my rad. took me about 45 min. - 1 hour.
had to get those tranny lines in straight.. so less time with out them.
Old Jan 4, 2003 | 11:22 AM
top hose looked fine, bottom hose looked quite dry. after removing them, the top hose was starting to go crumbly around the thermostat housing, so i replaced them both.
91 rally sport
22
Apr 5, 2016 05:06 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
