dexcool
Old Dec 29, 2002 | 08:20 PM
demonchild's Avatar
dexcool
does anyone know the ratio of dexcool to add to the raditor if it is completly flushed?
Old Dec 29, 2002 | 09:20 PM
biff85ta's Avatar
Car: 04 Vette
none dexcool if not kept in an ideal situation forms acids that attack every part if the cooling system.
Old Dec 29, 2002 | 11:04 PM
MdFormula350's Avatar
http://www.startribune.com/stories/435/21199.html
Old Dec 30, 2002 | 03:55 AM
biff85ta's Avatar
Car: 04 Vette
that article does not mention the cause of the low coolant level on those vehicles which usually turns out to be a radiator cap that stuck slightly openallowing small amounts of hot coolant out to evaporate and then sucking in air when the system cooled.
Old Jan 23, 2003 | 09:16 PM
patrickm00's Avatar
Vehicles equipped with DexCool coolant, which may have been operated for extended periods of time with a low coolant level, usually in excess of 20,000 miles, may be susceptible to the formation of rust-like material in the coolant system.
i'll be sure to switch back to prestone next time i plan to go two years or so without checking my coolant...
and 50/50 is usually the optimal mix for either type of coolant
Old Jan 23, 2003 | 10:21 PM
demonchild's Avatar
hey
your like a month late...where were you...lol
Old Jan 24, 2003 | 06:10 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Here is some firsthand info. I have 4 GM vehicles running DC, one the 89 rock was converted the other 3 factory fills. After 40k miles or so none of the 3 factory fills had any problem until the one Blazer developed a leaky water pump. It had run that way for a little while until I picked up the leak(wifes car, lucky it has gas half the time). It developed a brown fine coating in the rad similiar to rust that seemed to attach itself. I flushed the system and it seems OK now. One of my friends works for a local municipality with a fleet of GM cars running Dexcool. He seems to say about the same thing, if the cooling system is well maintained DC is a good coolant. However if a problem occurs or the system is run low DC will develop this brown appearance. I converted the Camaro right after DC became readily available and it has been fine for years. I did completely drain the block and replace all the rubber components when I converted and it looks just like when I put it in. My friends at the local GM dealer are evenly split on this subject so who knows.
Old Feb 9, 2003 | 09:45 PM
johnt's Avatar
Dex Cool has a chemical base that acts as a passivation of the internal metal parts, which creates a corrosion resistant coating. This is why the Dex Cool lasts longer than normal "green" coolant. I believe it is also silica free.
89 formula TPI
Oct 6, 2015 08:40 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
Danno
Dec 8, 2004 03:49 PM
Duck
Jul 19, 2004 12:27 AM
Danno
Mar 5, 2003 11:40 PM
