Running hot at high speeds, radiator ?
Old Jan 11, 2003 | 07:55 PM
IROC57TPI's Avatar
I am replacing my stock radiator with something new and would like to get something more efficient, yet stock looking and reasonably priced.
I don't know if this is my problem, but I have a 160* stat and at speeds of over 85MPH the engine gets progressively hotter until it hit 240*. The rad is stock and I have already cleaned all the debris out of it, but i think it may be all plugged up inside.
Old Jan 11, 2003 | 08:45 PM
ctandc's Avatar
Could be a dumb question...BUT......
Overheating only at sustained / higher speeds is usually a sign of a missing or damaged front air dam. At speed, there's nothing to help air get up to the radiator.
Check you're air dam first, it can't hurt.
As for replacing the radiator, IMHO, the 1-core alum radiator that comes on the F-Body stock is plenty for even a STRONG engine. When I wrenched on G-Body's that was a VERY popular swap for keeping dropped in engine cool.......
HTH
Old Jan 12, 2003 | 12:49 PM
IROC57TPI's Avatar
Got the airdam. The car was jsut repainted and all of that stuff has been put back on as it was.
I may just get a new rad, how much are they?
Old Jan 12, 2003 | 01:17 PM
MdFormula350's Avatar
you lower radiator hose could be collapsing, did you check that..
i bought a stock replacement radiator from Advance auto parts for 118 bucks from Modine... it works great..
Old Jan 12, 2003 | 08:28 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
If you replace your radiator you might want to look into getting new hoses for your application. They could be cracking and wearing out. So check them and you might be suprised when you take your stock one out. I was. It was clogged real bad plus cracked because it was plastic. To get a aluminum replacement. They are the same price.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
BBSDesigns
Aug 11, 2015 07:39 PM
