What other parts can i throw at this thing?
Old Jan 31, 2003 | 01:58 AM
NuclearPwrIroc's Avatar
Okay 89 tpi350. at idle only does it start to get WAY hot. fans are on, water pump and radiator are new. im losing coolant, but im not leaking it or burning it, wtf?
Old Jan 31, 2003 | 05:48 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Did you look at the oil? If it is milky coolant is getting into it. A very common problem is the intake manifold gasket leaking around the front coolant passage into the lifter valley. It also causes a pressure drop in the cooling system causing overheating. Do a pressure test or have it done, it's the best way to troubleshoot a problem like yours.
jaridjohn
Jul 8, 2024 03:49 PM
italiano67
Dec 11, 2016 09:21 AM
Bob88GTA
Aug 18, 2015 03:31 PM
1nastygta
Aug 8, 2015 07:38 PM
rsrmoore
Aug 7, 2015 08:44 PM
