Coolant leak is BACK!!!
Old Feb 6, 2003 | 01:39 PM
YellowIROC305's Avatar
Car: '86 Camaro IROC-Z28
Engine: 305 V8 (LB9)
Transmission: 700-R4
Just a few weeks ago I got the intake manifold gasket replaced, and paid a pretty penny for it to be done. This morning, there was coolent dripping on the ground, popped open the hood, and there were puddles of coolant in the EXACT same places as before! Did they mess up the repair? I DID start the car and drive it cold for a few minutes and then turned it off....then saw the leak. Was it just leaking because it was cold? I wonder this because I just started it back up, ran it up to temp, and turned it off and there is no leak.
Old Feb 6, 2003 | 03:44 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
there was prolly no leak because of no coolant. are u sure its coming from the same place?
Old Feb 6, 2003 | 04:10 PM
Well, I drove the car into town to get her washed, came back, popped the hood...no more leak. Coolant bottle is full, no leak. Craziness...
Old Feb 7, 2003 | 07:31 AM
MdFormula350's Avatar
thats weird!! :lala:
Old Feb 7, 2003 | 01:07 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Congrats! hah! I wish all my oil leaks would do that! Haven't had too much trouble with coolant though....knock on wood
-Paul
Old Feb 7, 2003 | 05:36 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: Coolant leak is BACK!!!
Yes, that's pretty normal. Residual coolant will drip for maybe week's to come. Also, a little known fact is that new repairs may leak somewhat until the engine is run up to temp. I lost an intake gasket rather catastrophically and it leaked after it was repaired or as I call it WEPT for a while. The amazing part was that I was running a 160 stat. After I put the 195 back in and gave her a good haul everything tightened up. I am not suprised you payed through the nose to get her fixed, it's a miserable job. I would give it 2-3 wk's, then bitch to the repair contractor.
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
