Wacky cooling problem and no heat
Old Feb 18, 2003 | 08:38 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
Not sure if the problems are related but they started about the same time. When I'm at a light or at low speeds temp starts rise to around 200 even with both fans on which used to keep the car at a constant 170. As I pick up speed tempature continues to rise all the way to the red in the span of less than a minute. It'll hold there for a few seconds then come down to normal temp just as fast. My heater, cranked all the way blows nothing but cold air even with the defrost on.
I've flushed the system, changed the thermostat and the CTS with no luck. Please help!
Old Feb 20, 2003 | 01:33 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
sounds like you classic air damn problem. look under the front of your car and look for a piece of plastic hanging down that is cruchial (i suck at spelling) to keeping your car cool at highway speeds.. i had the same problem for about 3 months and had to put my car away for a long time till i came across this sight. now car is the beast running ever!
Old Feb 22, 2003 | 01:36 PM
MdFormula350's Avatar
as far as the heater, the heater duct might not be opening..
Old Feb 23, 2003 | 07:59 PM
91 z28 350's Avatar
Car: 91 Z28
It could be the head gasket. My friends mustang did the same thing and his head gasket was blown. He replaced a water pump all radiator hoses and a thermostat and it ended up being the head gasket
Old Feb 26, 2003 | 11:51 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Your water pump might be shot. I just had the same problem. Do you notice any leaking of coolant leaking from the front of your engine or loss of coolant in your reservoir? These are possible signs of a bad pump. I replaced mine and everything was good again.
chazman
Aug 28, 2018 03:25 PM
Papaginos
Sep 27, 2015 03:29 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
TheExaminer
Aug 26, 2015 04:59 PM
chazman
Aug 22, 2015 02:01 PM
