Serpentine help
Old Feb 22, 2003 | 10:48 PM
zzghy's Avatar
Serpentine help
How do you guys make the serpentine setup work with out smog and ac? Ive heard that you can just remove the smog and get a smaller belt. Can you take the ac off also and get an even smaller belt? or would I need the delete pulley? Thanks in advance!!!!!
Old Feb 23, 2003 | 01:59 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...ne+smog+delete
Old Feb 27, 2003 | 12:47 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
There are 3 ways to do this:
1. Get the A/C delete pulley from GM (part numbers are on this site, use search) and get the Smog pump delete pulley. It was available for cars shipped overseas only but can be purchased through gmpartsdirect.com
2. Buy A/C delete pulley and use tech article linked above to bypass smog pump.
3. Re-route belt to eliminate both pumps, type up a tech article and submit it with pictures.
Good luck!
Old Mar 5, 2003 | 12:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
you can elimninate the smog pump and ac compressor and re-route the belt using the the tensioner still
ask TBI305Camaro about this
Galaxie500XL
Feb 1, 2020 04:53 AM
evilstuie
Jan 9, 2020 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
evilstuie
Sep 24, 2015 02:31 AM
