Where's my F-ing coolant going?
Old Mar 4, 2003 | 12:43 PM
E-man007's Avatar
Im filling my coolant reservoir about once a week.There's no obvious puddle under my car either.Then when it is full the engine is still running hot for a while then cools down, then when I think everythings alright the temp fluxuates back and forth.Could it be a bad water pump?
Old Mar 4, 2003 | 02:20 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
water pumps usually leak when they are bad. It would be pretty easy to see if it was leaking. I would think the seals on the tank of the radiator. Mine would leak there and it took forever to find it. The problem is that it is so hot there that the water disappears so fast. Try cleaning the tanks and watching them when you park. Also wouldnt want to think that it may be the heater core. Any smell?
Old Mar 4, 2003 | 02:35 PM
KC10Chief's Avatar
You definately don't want it to be (gasp), a head gasket!!! Matt
Old Mar 4, 2003 | 09:46 PM
MdFormula350's Avatar
try tightening most of the coolant lines, it could be leaking and then burning off on the manifolds.
Old Mar 4, 2003 | 09:51 PM
KC10Chief's Avatar
*** point. All those coolant lines that are above the valve cover on the passenger side can leak and it will either drip right onto the manifold, or onto the valve cover and then onto the manifold. There's lots of clamps there. One could be loose! Start your car and watch that area closely and see if you can see anything drip. Also, look at your valve cover on the passenge side and see if you can see any antifreeze on it anywhere. Good luck! Matt
Old Mar 4, 2003 | 10:01 PM
bigals87z28's Avatar
Car: Check The Sig
watch out! this can happen
Old Mar 4, 2003 | 11:57 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
WOW that must really suck big time and then yet to have to motor sent to be cleaned out. damn
Old Mar 5, 2003 | 11:58 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
passenger side floorpan?
Old Mar 11, 2003 | 10:34 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
bigals87z28,
Did a hippo take a dump in your lifter valley or something?
Old Mar 11, 2003 | 11:45 PM
Car: Check The Sig
hehehe no... it was a zebra... but close..heheh nah... i got that pic off this site... its a 350 vortec truck engine... they guy wanted to know where his coolant was going... never checked his oil i guess... its that weekly maintance that prevents a stuff like that man... speakin of which... i gotta go check the trans fluid... i think i gotta leak in the pan or gasket... its drippin a little bit at a time..
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
