Adding reverse flow cooling?
Old Mar 7, 2003 | 02:30 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Is there anyway to add this to an L98? I don't mean to add the Lt1 heads or intake just to reverse the flow of coolant on our engines, what would it take to do this?
Old Mar 13, 2003 | 03:25 AM
JPrevost's Avatar
Car: 91 Red Sled
Good question. I'm not going to hypothesize but I can't see it being too difficult with an externally plumbed electric water pump. Just put it evenly into the intake manifold and install the thermostat housing on the lower radiator hose.
I would think you would just need to run coolant mostly to the back of the intake manifold/heads and slightly less to the front. Then gut your stock water pump. I wonder what would happen if you just used a reverse rotation pump (v-belt if you've got serp) and then install the thermostat in the lower line. The biggest problem would be air pockets and tuning.
Old Mar 13, 2003 | 01:42 PM
92Transam's Avatar
I guess I should look into how they do it on the 4th gens a little more, but I thought it seamd pretty easy to do on paper thus the reason I asked, well thanks for you info.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
